Image not find for restore
Wish a happy new year anf have to say thanks for the good product.
Have a small installation with three clients. Images as well as full file backup completed without any issue. Now trying to restore the Image for one client and receive a permanent error saying that for the client an image is not available. Is identical in restore client 1.1 and 1.1.1. Server is found, clients on the server are identified as well, but image is abviously not found.
Client: HP ProBook 350G1, 6 GB RAM, 1 TB HDD, Win7 Home 64Bit, UEFI and GPT (Probably eror source)
Server: HP ProLiant Microserver Gen 8, Windows Homeserver 2011, 64 Bit.
Probably GPT is the source and the error message is misleading, but not sure whether there is something else wrong. Appreciate help.
140104 - New Status - tried a manual restore from command line, but couldn’t locate Urbackup_client, which is needed. Checked all locations listed in path - assume is stored somewhere in user, but path does not include that user. Appreciate an info where the client is located in the restore filesystem.
Thanks for your help
It’s located at /root.
The image should be listen, even if it is GPT formatted, though I haven’t tried this yet. The message displayed is No images for client XXX found ?
Thanks for the fast reply. Restore-client is still not functioning, error message repeatable, content as you replied. Via commandline - could mount and see the image and restore the files, but not MBR. Obviously client not bootable without MBR, but can reinstall.Message sequence for MBR is as follows :
Loaded -fsimageplugin- plugin
creating socket …
done.
Server started up successfully!
Looking for old sessions… 0 sessions
Have cancelled after 45 minutes of inactivity
Have to admit - saw the hint to root after I read your reply.
