I am new to UrBackup. I have the client running on a Windows 10 system and the server on a Ubuntu 20.04 server.
I tried changing the locations that should be backed up and chose “choose manually” and set it to a test directory. However, UrBackup seems to save my whole C drive.
Where can I change/ choose the right locations?
Thanks,
Adam
Any suggestions? I also cannot find anything in the documentation.
Sorry for my noob question…
Keep in mind the difference between file system backup and image backup. On Windows the default behavior is to create both. So I guess your client tries to first create the image backup (complete system) and will then continue with the file backup based on your configured paths.
Thank you very much!
I am running my first backup now
