It doesn’t seem to want to compile. I can’t find it when I follow the compilation instructions.
Are the binaries mentioned here the newest ones for this?
Checkout the code from github and run ./update_restore.sh
(https://github.com/uroni/urbackup_backend/blob/dev/update_restore.sh). Needs g++/clang++, autotools, libz-dev. You might have to modify the script a bit…
Thanks a lot. You’re the man!
