after restoring the image with the boot cd shows me the following error “cannot read mbr data”
Can you try, if it works with this one? http://sourceforge.net/projects/urbackup/files/Restore/1.1.1/urbackup_restore_1.1.1WIP.iso/download
thank you very much for your answer but I think i´m pretty sure that is exactly the same that im used before. but let me try again.
I been Having this problem too, but due to that im new, and that i have not been at work this week i couldnt done more testing.
Is there any log or something on the restore that we analize or sabe before rebooting and testing if the Bare Metal restore worked ?
Thanks in advance
Juan
The are two logs in the /root
directory when restoring.
To get those:
- CTRL+ALT+F2 to get a console
sudo su
to become root -
cd /root; cat restore_mode.txt
to show the log
Which server version are you using? In 1.4.6 a bug was fixed that caused the server to crash after the first image was restored. This could have caused the error described by the OP.
