The logs are empty, there Is a problem with the shadow copy, but this issue does not apply.
tail /var/log/urbackup.log
2013-05-27 09:53:52: WARNING: Filename “Документация ООО Фирма Кубаньэкопроект для участия в открытом запросе предложений на разработку природоохранной документации.part09.rar” too long. Shortening it.
2013-05-27 09:56:45: ERROR: Activating shadow copy on “pc04” for path “e” failed
2013-05-27 09:56:45: ERROR: Activating shadow copy on “pc04” for path “f” failed
2013-05-27 11:11:41: WARNING: Filename “Перечень документов представляемых для проведения паспортизации и согласования паспортов опасных отходов и получения свидетельств 20.doc” too long. Shortening it.
2013-05-27 11:11:41: WARNING: Filename “Ситуация по заболеваемости инфекционными и паразитарными заболеваниями в Краснодарском крае за 11 месяцев 2011 года характеризуется как стабильная.doc” too long. Shortening it.
2013-05-27 12:27:47: ERROR: Pipe to client unexpectedly closed has_error=false
2013-05-27 12:27:48: ERROR: Backup not complete because of connection problems
Just launched a full file backup, there are no errors, backup is made, the size of 0 bytes
421 ECOSERVER Full file backup 2013-05-27 13:15 1 min 0 bytes
It would be helpful if you change the loglevel to “debug” (etc. in /etc/default/urbackup_srv) and restart the server, start a backup and post the resulting log messages, because the error is difficult to see currently.
The client settings may differ, but the default “include files” setting is “C:\WINDOWS\system32\config*;”. You may want to change that to “C:\WINDOWS\system32\config*;C:*;E:*;F:*”, otherwise files from those drives will not be included in the file backup (Only files matching the include_file pattern are backed up).
If that wasn’t the issue I’ll have to investigate, if volumes as default backup dirs still work correctly.
