I have some old log entries from when I first found and started using UrBackup. Most of which are errors form my mistakes. Was wondering if there is any way to delete or clear these from the log?
Short of firing up something like SQLiteStudio & manipulating the database directly I can’t think of one.
It’s not an approach I’d particularly recommend unless you know what you’re doing though.
