Client config change cause issues
Hi All,
I have noticed that some of the backups on specific windows clients are not working,
Banging my head finally I found it, When a client add a backup path on the windows client something is going wrong.
Since the change the server the error is Index error,
I have verified this on 3 clients.
Server 1.47 client 1.47 and 1.44
Till now I haven’t found a way make the backups work again,
Many Thanks
David,
Can you post some logfiles/log entries?
Thanks for the prompt reply,
I think I found it.
The problem is that in the client config I have added a path with an /optional.
If the optional folder does not exist thats where the problem is,
So the log states Cannot access directory to backup :"\?|globalroot\XXXXXXXXX and the index does not continue from there,
I have delted the optional directory from the client gui restarted the client and all is working again.
Thank You…
Maybe I can suggest a quick and dirty solution for that.
Is it possible to first backup the user requested folders and after that move to the server requested folders?
Thanks Again,
