Hi Martin, i wanna ask you about the bandwidth usage of Urbackup, in 2 different networks i have the same problem, the system where the Urbackup server is running becomes to slow when Urbackup client start, this happens in a networks with 20 host aprox (in the Urbackups server settings i set the limits to 5 connections at time) and another networks with 2 host only, one is the the Urbackup server with a Urbackup client installed and the other is just the Urbackup client.
In both cases when only 1 client are doing the backup, the access to any software o share in the Urbackup server becomes slow, and become even slower with every Urbackup client that connects to the server.
It’s any way to improve this? any config to limit the bandwidth use by Urbackup?
Both servers have Windows 2008.
In your blog i read that the version 1 of Urbackup will have a way to limit the bandwidth, but if is possible to do it in this version let me know.
Another question, it is possible or exist any way to set the image backup in specific days, like every Sunday or the first Sunday of month or similar?
Thanks a lot
you could just use that version:
https://sourceforge.net/projects/urbackup/files/Server/1.0RC/
It should be stable.
It IS stable. I can confirm stibility for backups and restores (file and image), cleanup, logging, mailing, statistics, user accounts, permissions, bandwidth usage. I did not test archival and internet.
