Good day! Tell me why the full backup of images does not work for me on a schedule, only the file backup works.
Should a full backup of images work according to the schedule ??? (It only works if you manually launch it)
GetVolumeInformation failed with error code 21. Skipping…
2018-11-26 18:37:59: FileSrv: done.
2018-11-26 18:37:59: FileSrv: Disabling new behavior…
2018-11-26 18:37:59: FileSrv: Servername: -WIN-RK-
2018-11-26 18:37:59: FileSrv: Server started up successfully
2018-11-26 18:37:59: Filesystem. Vol="\?\Volume{c41d4801-e19e-11e8-80b3-806e6f6e6963}" Name=“зарезервировано системой” Type=“ntfs” VPaths=0 Size=366997504
2018-11-26 18:37:59: Bootable flag set for volume
2018-11-26 18:37:59: Found potential candidate: \?\Volume{c41d4801-e19e-11e8-80b3-806e6f6e6963}\ Score: 3
2018-11-26 18:37:59: Filesystem. Vol="\?\Volume{c41d4802-e19e-11e8-80b3-806e6f6e6963}" Name="" Type=“ntfs” VPaths=1 Size=31843151872
2018-11-26 18:37:59: Filesystem is System partition. Skipping…
2018-11-26 18:37:59: ClientService cmd: STATUS#pw=QMfwYFHBCmD8fINRkZv686Ay3Kp8dF
2018-11-26 18:37:59: FileSrv: UDP Thread startet
2018-11-26 18:37:59: ClientService cmd: STATUS DETAIL#pw=QMfwYFHBCmD8fINRkZv686Ay3Kp8dF
2018-11-26 18:38:00: ClientService cmd: STATUS DETAIL#pw=QMfwYFHBCmD8fINRkZv686Ay3Kp8dF
2018-11-26 18:38:00: Internet mode not enabled
2018-11-26 18:38:00: Looking for old Sessions… 0 sessions
2018-11-26 18:38:00: Final path: C:
2018-11-26 18:38:00: Filesystem. Vol="\?\Volume{c41d4807-e19e-11e8-80b3-806e6f6e6963}" Name="" Type="" VPaths=1 Size=-1
2018-11-26 18:38:00: GetVolumeInformation failed with error code 21. Skipping…
2018-11-26 18:38:00: Filesystem. Vol="\?\Volume{c41d4806-e19e-11e8-80b3-806e6f6e6963}" Name="" Type="" VPaths=1 Size=-1
2018-11-26 18:38:00: Selected volume \?\Volume{c41d4801-e19e-11e8-80b3-806e6f6e6963}
2018-11-26 18:38:00: System dir: C:\Windows
2018-11-26 18:38:00: Volpath: \.\C:
2018-11-26 18:38:00: Device is not GPT formatted (0)
2018-11-26 18:38:00: Found no EFI System Partition
2018-11-26 18:38:01: ClientService cmd: STATUS DETAIL#pw=QMfwYFHBCmD8fINRkZv686Ay3Kp8dF
2018-11-26 18:38:02: ClientService cmd: STATUS DETAIL#pw=QMfwYFHBCmD8fINRkZv686Ay3Kp8dF
2018-11-26 18:38:03: ClientService cmd: STATUS DETAIL#pw=QMfwYFHBCmD8fINRkZv686Ay3Kp8dF
2018-11-26 18:38:04: ClientService cmd: STATUS DETAIL#pw=QMfwYFHBCmD8fINRkZv686Ay3Kp8dF
2018-11-26 18:38:05: ClientService cmd: STATUS DETAIL
