Backing up to an external drive
I have backed up several pc’s but now need more space so I went to just back everything up to an external drive but it wouldn’t let me. Is there any way I can do this?
Should work. Can you give a few more details about your problem? Are you trying to move the files UrBackup created to the external drive?
No, I’m trying to back straight up to the external drive. Just set urbackup to backup to the specified path. I tried it once before and it wouldn’t set to that path.
Weird, are you using the Windows server? If yes, does “LOCAL SYSTEM” have permissions to write to the folder you specified?
