Is there any way to back up a component and all subcomponents without explicitly listing them?
Example:
Windows Internal Database is installed on a computer. In the component selection I check WIDWriter, this will also select the databases “master”, “model” and “msdb”. I will install WSUS on the computer, but if I want to back it up, I have to manually add “SUSDB” to the list of backed up databases. I would need it to be automatically included among the backed up databases.
If this option is not available, please consider this text as a feature request. Also, in this case, it would be nice to be able to explicitly exclude some subcomponents (databases) from the backup, so that the automatic addition of databases described above works, but at the same time it would be possible to not back up some databases.
Thanks in advance for the answer.
Jana
